While removing the starter bracket and starter as one piece together I removed the first hex nut on the threaded stud on front of the sarter then the red wire and then the second hex nut at this time the stud that held the wire and two nuts moved in and out then after putting all back together after rebuilding my carb then I hooked the negative to the battery and positive to the battery it totally arced bad enough to melt the metal that holds the positive cable on the battery ! My question is the stud on front of the starter by me taking the hex nut loose and was able to move the stud in and outward could something on the inside of the starter fell off the stud causing that much arc like a short going to ground?
