acarter1106
- Jul 25, 2013
- 4
I have a 2005 Evinrude 40 outboard that we started having problems with a few weeks ago. The first problem was the engine would rev on its own. The engine then began cutting out but would restart fine. It wouldn't cut out while idling but would cut out once it accelerated. With those problems, we replaced all of the fuel lines along with the fuel pump and added a fuel/water seperator thinking it may have had something to do with a leak or water in the fuel line. We took the boat out yesterday after replacing all of this and the motor cut out again but we were able to restart it. We continued on, and the motor cut off a second time and now it will not start at all. Any suggestions?
