I brought a carby kit and installed it. I primed the fuel lines before trying to start the engine and fuel leaked from the front of the carby. I'm not sure is some leakage is normal? I started the motor and it seemed to be running very rich with the low speed adjustment knob having no effect on the idle. I screwed the low speed needle all the way in and then backed it off 1-1/2 turns when first installing carby kit as per instructions in manual. I couldn't run the motor very long as the impellor needs replacing. Any advice on what I should do to the carby next would be appreciated
Regards Kevin
Regards Kevin
