Curran Bishop
- May 27, 2013
- 7
I'm having a problem with my pressure tank continuing to pump gas to my motor on my '57 Johnson 18. Both times I've noticed the problem I have already opened the cap on the tank to release the pressure, and heat from the sun seems to increase pressure sufficiently to being pumping fuel to the motor (and all over the motor well...). Apart from just leaving the cap partially open, is there a way to shut off the fuel line? It seems that leaving the a cap open will cause a lot of gas to evaporate between uses... any solutions?
Thanks!
Thanks!
