This is a 1965 Johnson JW20B 3hp.
It has a fuel pump and a connection for an external tank, only problem is that it shouldn't be there, but looks factory. I can find nothing in any of the parts diagrams that shows this setup.
Can I bypass this for the moment and run the line from the integral tank directly to the carb? From what I was told when I got the motor they couldn't get gas to the carb, I am guessing this is the problem.
Cannot find any markings on the fuel pump except a small m at the bottom right corner of the pump. I would certainly love to find a rebuild kit for it.
Chris
Chris
