Engine runs well at mid to top end speed for 1/2 to an hour. Iles well to begin with. When you back it off close to idle after warmed up, it wants to run rough then die. Carbs. are clean. Idles well at first. Could it be pulse pack, coil or rotor cap overheating? And how might you test these with or without being warmed up? Thank you for any info.
