cooperskanoo
- Jan 17, 2013
- 11
To fill u in. 1980 j35elcsm was steaming so replace head gasket and decked head and new thermostat, and watrr passages seem clear. which didn't fix steam issue so I looked to my "clymer" manual for help and decided to do my timing. My question is that when I do the initial timing do I do it with the motor running or not because the timing marks on the cam roller move about a half inch backwards once the motor is started. My theory was make them align while its running. Now with that said, it idles extremely high, by ear probably 1500 rpm and all my linkages are backed off and there is no screw in the idle adjust at the cable so that's not doing anything.
Where have I gone wrong because this is seriously doing my head in.
Any help please?!?!?!?!?
