After motor started running rough/stalling at low speed, tried WOT and didn't get usual take-off/speed/RPMs (fuel, compression are good) and I thought spark was too; stopped to pull plugs and have a look at them - 3 were warm under plug boot, 1 cold, 3 warm ones all looked normal/good, but cold one was kind of wet and black - wet fouled I would call it. Swapped plugs, same result on that cylinder. Switched 2 coils, same plug/cylinder was cold after another run. That eliminates coil right? That plug has spark when you pull and hold to block while cranking engine, but I think is losing it under power - Sound right? Powerpack probably?
Any insight or advice you could give will be much appreciated! :joyous:
