Hi looking for some help if possible , I have a Johnson 150 vro outboard on my boat that I just bought , on my first time in water it has shown a problem when going on full power it would go fine going slow , and when you put it on full power it will go great for about 10-30 seconds then just die as if it had ran out of petrol, if you start it up again rite away it starts no problem and away you go , no miss fire or stutters ,
Things I have tried.
Brand new fuel tank
New fuel line
New primer new fuel filter
Cleaned out carbs
New spark plugs
The only other problem I have is when starting from cold if will fire up straight away no probz but will run and cut out a few times trying to get it to heat up , if you get it to tick over and pull away it runs fine and will tick over then when you start it again you need to catch it with throttle
Any help would be great thanks
Brand new fuel tank
New fuel line
Cleaned out carbs
New spark plugs
