Experiencing sluggish or low rpm WOT. Idles great. I can't squeeze the primer bulb to the point that it stays firm. While on the water, at WOT, if I hit the cold start primer cylinoid button momentarily once or twice, it takes off for about 10 seconds then gets sluggish again. While parked in driveway, I pumped up the bulb and can see fuel coming from either the fuel line feeding the cold start cylinoid or the smaller feeder lines going to the carbs. Will that leakage cause WOT issues?
