Hey, I recently bought a boat with a 100 horse 1972 Johnson. It is a 4 cylinder 2-stroke engine. It runs fairly well immediately after starting, but once it warms up it randomly bogs, skips, or even dies at all ranges of throttle. It is considerably worse however at lower RPMs. Also, when I took it out for the fist time the other day, it had no power under load. At full throttle I was traveling at a blistering 10 Mph. The guy I bought it from says the carbs were recently rebuilt and they do look quite clean on the inside, so I'm pretty sure it's not that the carbs are dirty. I did notice that all of the low speed needles were screwed in all the way, which seems wrong but I'm not sure how to adjust them. I thought that the problems might lie in the spark plugs/ignition system, so I pulled the spark plugs and took them to several auto parts stores looking for replacements. Unfortunately, no one around here had any of the old school Champion UL77V plugs, so I was wondering if I could replace them with a better, more modern plug? Anyway, this is my first boat and I still have tons to learn, so the problem could be something really obvious.
Any suggestions would be great, thanks!!
