Re: 1992 Johnson 48 SPL Carburetor Adjustment
I beleave you are correct on the static setting. You have to set one carb at a time, about 1/8 turn at a time, to get the best idle. It can be a job to set duel carbs, takes patience.
It's best to do this in the water with the boat in the water in gear.
