2005 Johnson 90 HP Engine Stalls
Bronx68
After running the engine for a short period. I'll shut it down to fish and then restart it. It stalls out several times before I can get it to run without stalling. When running along at cruising speeds it runs perfect. What should I do to troubleshoot this problem? I plan to drain gas and put fresh gas in with Sea Foam. Engine has very low hours but original plugs.
