Good day:
I would really appreciate some assistance with this.
I recently changed the water pump and prior to this never had a problem with the forward gear engaging; reverse works fine but neutral was at times also difficult to fully engage.
While changing the water pump I was very careful not to knock or pull on the drive shaft.
While having it in forward the engine revved fine but I could hear what sounded like a gear not meshing.
Again, this is a long shaft; the shift rod connects at the lower end where the water intakes are located.
What could I have done wrong?
Thank you in advance.
Larous
Larous
