Please Help:
I removed lower unit to replace water pump. Removed housing, impeller etc. removed plate cleaned old gasket under plate.
Is there supposed to be some 0 ring under the plate? (My motor does not have one). Installed new gasket, then plate, then o ring, then impeller blades pointing to right in the impeller liner, then small o ring in housing between liner and housing, and large seal on bottom of housing, put grommet in housing, installed cover, put grommet in larger hole in cover, put o ring on driveshaft. Is this correct or am I missing something??? Tried to put lower unit back on, shift cable not going thru hole, can not install lower unit?
