I was going to take the lower unit off to replace the water pump, and I noticed I could still spin the prop at the bottom regardless of whether it was in neutral reverse or forward, It's not a spun prop because the shaft still did move after I took the prop off. Also when I took the prop off the oil looked really milky (see picture below) and I don't know where to go from here in terms of repair. Thanks for any help.
http://i.imgur.com/qMJBNv9.jpg
