first of all thank you to all the iboat community for assisting me with my other problems. one last problem or issue though. i have a 1977 70hp evinrude (70773) with a power pilot control box. without the cables attached to the motor i can shift the motor by hand to forward,reverse neutral. but when i attach the cables i can get the motor to shift in forward or reverse but when i try to put it back in neutral it wont go all the way to neutral. I am also doing this without the motor running. does that make a diference? cables out of adjustment? if so detailed info on how to adjust. thank you
