1959 Johnson 35 HP Gearcase Seal Replacement
Hello i have a 1959 Johnson 35 HP Model RDS 21-B. I am on the task of replacing the seals in the gearcase. Can someone tell me how to remove them properly without damaging the cast aluminum. Step By Step instructions would be nice. I have already purchased new impeller seals and the seal kit for the motor. It comes with two brass seals and drain/ fill hole seals the seals for the shift rod and the spaghetti seal for the housing. Thanks for the help if anyone can.
Daviet
Re: 1959 Johnson 35 HP Gearcase Seal Replacement
You are going to have to drop the lower unit and seperate the skeg to replace the seals. A factory manual is worth it's weight in gold for proper repairs on your engine.
I already have dropped it before and replaced the water impeller. Do you have any advice for changing the seals? A Procedure would be helpful
Daviet
You have to split the skeg off of the lower unit itself and remove the propshaft. remove the seal housing from the propshaft and then you can replace the seals.
kfa4303
Banned
HI 1961. Here are some great links that can walk you through the job. They're for a slightly different model, but all of the basic steps are the same. You van get the reseal kit itself right here at iboats for about $25.
http://forums.iboats.com/johnson-ev...l-kit-1968-evinrude-fastwin-18-hp-601481.html
http://forums.iboats.com/johnson-evinrude-outboards/fastwin-lower-unit-seal-faq-277190.html
Evinrude / johnson 18-20 hp LOWER UNIT disassembly - YouTube
1959 Johnson RD-21 35 hp Outboard Motor Parts
HOW TO PULL SEALS FROM LOWER UNITS - YouTube
