done a lot of searching but havent found anything on this particular motor, does anyone know the procedure for performing this adjustment. right now the butterfly just starts to open when the roller, looking at it from the front of the motor, is about 1/4 inch to the left of the timing mark on cam plate. The motor starts first pull cold but if I shut it down for a while after warmed up it seems like I have to choke it and pull 4 or 5 times to get it going again. I would think after its been running it should start with half a pull and no choke. not sure if this is my problem but figured a good place to start. thanks
