I've only had this motor a couple weeks and it ran great the previous two times I've used it. Yesterday, it started up fine and ran for about 30 minutes of start and stop use but then just died while running. Whenever I tried to restart the motor, it would hit and die but would not stay running. I pumped the bulb until hard but the motor still would hit and die. After a couple attempts it would no longer even hit. Any help on this would be greatly appreciated.
Update: I sprayed starter fluid in the intake and the motor will start but die almost immediately. I pulled the bowl screw from all 6 carbs and they are full of fuel. I also purchased new plugs and they are set at .40. The inline filter is clean. Plugs are sparking. I'm lost on this one.... Thank you in advance for any help offered.
