Re: 1957 7.5 hp Johnson stuck in reverse.
The little guy is stuck in reverse no matter where you put the shifter... We were out on the boat and were cominig in to dock and my wife was running the motor and I had her go to neutral, then reverse then back to neutral... well she stayed in reverse. The motor that is... LOL
Here's the other thing... I'm extremely new to boating and might not know or understand everything you're saying...
When you say "On that motor, you have to pull the powerhead to get to the connection point. The shift rod feeds up through the connection bracket."
Where's the connection bracket and what do you mean by powerhead? LOL I know, that's terrible because they seem so obvious...
Thank you for your help!
