whitejd12
- May 31, 2013
- 155
Here's some pics of my torn apart lower unit and gearcase. If anything doesn't look good or needs cleaned, lubed, greased etc, please let me know. Here's the bottom of lower unit, above gearcase.
Here's the top of lower unit, where water pump will set.
Here's the gearcase cover, very bottom. The oring/gasket that goes around the edge of this cover, I'd like to replace, but can't find part.
Here's the gears.
Here's the bottom of the motor, above the lower unit, looking up.
Cleaned everything up. Gonna order parts and put back together. Does everything look OK?
Jeff
Here's the gears.
Jeff
