bunchadeans
- Jul 13, 2013
- 3
I have a 1971 40hp evinrude norseman, the flywheel key sheared while running, and I have to replace the flywheel. I was wondering if I need to set the timing and if so what is the procedure for setting the timing. The flywheel has a large split in it, that is why I am replacing the flywheel. This boat had set for two years and I have been rebuilding it. Thanks for your help.
Bunchadeans
Bunchadeans
