Hi Everybody,
I'm new to the forum here, but I've tried researching the best I could without asking questions, and this forum has been great so far!
I do however, have a problem I can't seem to figure out myself. I am getting water in the bottom cylinder on my 75 hp Stinger, while the motor is down in the position it would be in the lake. I assumed that would mean the head gasket is leaking, I pulled the head off and that did not appear to be the case and I put a new head gasket in. Immediately after starting the engine on the muffs, I had a significant amount of water back into the bottom cylinder. I don't think a head gasket would have been able to leak that much in that quick, especially with it just being replaced. Where else could it possibly be leaking? Is there such a thing as frost plugs or something similar on these engines? I've never honestly done much work on outboards so I'm new to this.
Thanks in advance for any help you're able to offer!
