Ok i've posted on here several times about problems with my engine.
What I've done so far
* Rebuilt and replaced bowls on Carbs
* Removed cleaned and installed new gas and Oil
* removed oil Injection (followed instructions in Clymer Book)
* Replaced all fuel lines and Bulb
* Replaced gasket and o-ring on ful filter
* Took apart fuel pump and seemed to be OK
The problem I had before all this was it would go to about 1/3 throttle and then bogg down. Then once I did all of this it will now plane but it's only running at 2/3 power it seems. When I have it throttled all the way and I squeeze the bulb it wants to go full power but doesn't. What am I missing? Anything anyone can suggest would be appreciated.
Could it be the fuel pump even though it looked ok inside? Some one mentioned the little piston inside the fuel/oil pump that I should remove it because it sometimes gets stuck???
Please help
I don't want to take it to a shop and spend more money on it. BTW it starts first try and idles great.
Michael Schraer
Please help
Michael Schraer
