Hello,
I have a 1983 Evinrude 140HP that is having a problem with the tilt/trim. The motor would trim and tilt fine but would not stay up. I noticed it was leaking fluid around the trim rods and I have replaced all the O-rings associated with the trim rods. It still doesn't stay up. It will go all the way down. I have read several different posts and in several places some of you have indicated the check valve is probably bad. I have looked at an exploded view of the unit but none of the valves are called a "check" valve. In the pic below I have circled the valve that I believe is the check valve. Can anyone verify that is the right valve?
