Have a 1979 evinrude 75 hp outboard that starts and idles on land, but doesn't accelerate on water. I have to adjust with the choke and carb linkages to get it to go faster than 5 miles per hour on water. Otherwise, when you throttle forward, it just bogs down.
I've taken the carbs off and cleaned them, everything seems put back together correctly. I made new gaskets for my air intake box, but I highly doubt they are causing this problem.
Carbs need rebuilt?
Carb #323714
Engine #75943R
Carbs need rebuilt?
Carb #323714
Engine #75943R
