I have a 90 hp Johnson on a 21ft pontoon with a 13 pitch prop. My max rpm is 5000 with 2 people and very little gear. With 4 people and same gear I drop to 4700-4800 with 8 people I drop to 4100. I was told 5500 was max rpm for this engine. But never can hit close to that. The engine seems to run fine. Just not shore if I should try to change prop or adjust something on engine. Also my prop now is beat up and needs to be replaced but not shore what size to change.
Thanks for any help
Thanks for any help
