Motor was cranking and running fine until I replaced the red manual valve on fuel solenoid. It was cracked and leaking fuel so i changed it following the direction. After it was changed... the gas leak caused the epoxy to soften and the electrical part slide out of the solenoid body. I got a used body and repaced the internal parts with mine. Now it will not start...unless i keep trying and trying.When it does crank , it run fine and cranks easy for a day or two. I pulled the main gas line from solenoid and gas flows when cranking but when the small line are disconnected (with the main line in place) no gas flows(some bubbles and a couple of drops) out even when i push key in and turn motor over. The solenoid is making a clicking sound when the key is pushed in. I have replace plugs, filters, fuel line and bulb.
