thilderbrand
- Jun 24, 2013
- 2
I have a 68 johnso 6hp. engine runs strong when the hood is off but when i put the hood on it bogs down and stutters. What can be causing this?
Hmmm, What about the exhaust cover gasket?Are you running it in a barrel? I've had the experience where a lot of smoke would accumulate around the barrel and when the motor sucked that in, it would falter. If it's out in the water and does it, maybe there's an exhaust leak.
About the only place on this motor (unless there's a hole somewhere rotted thru), would be the powerhead-to-base plate gasket.
If it were leaking somewhere, exhaust would flow right into the cowling and cause poor operation.
If you haven't run it on the boat, try that and see what happens.
HTH...........ed
