got a 65 5hp johnson. model LD 10S. its perfect for a little 12ft alumacraft in a lake i like to fish that has a 10hp motor restriction.
when i pump fuel to the carb with the tank line bulb, its leaking out of the fuel pump. the engine is running good, but the choke has to be pulled out some for full throttle. i rebuilt the carb a couple of seasons ago along with the points and new coils. before i pull the carb down again and clean it i want to address the pump.
problem is there are no kits for this pump. it was only used for a couple years and then they went to the standard little square pump that takes the 393088 kit.
what would you guys do for this fine little motor? many thanks for your help/advice!!
