manderson7
- Aug 24, 2011
- 1
This weekend I started having some trouble with my trusty 1964 johnson seahorse (40hp) I got it fired up just fine however once I would accelerate over 10 mph the engine rpms would continue to increase but prop would stop turning. This problem has persisted ever since. After I got the boat back to dock to play with it I started having trouble starting it - once the starter pinion gear drops of the flywheel the engine dies leaving an electric whine.
In the past week I had a log jam between my propeller blades and the lower unit while docked and I tried to reverse out before discovering the jam causing the blades to dig into he wood. Other than that everything has been working great.
I'm guessing there is something wrong with the fuel intake - but i'm not a motor head. Any thoughts or suggestions would be great.
Thanks,
Michael
Thanks,
Michael
