Have a 1968 9 1/2 hp Evinrude Sportwin. Runs good at 3/4 choke. It will idle smoothly. When I open the choke all the way it wants to die unless I am at 3/4 throttle or more. Has new gas and oil mixture at 50:1. Motor has sat for 2+ years. At 3/4 choke it starts on the 2nd or 3rd pull when cold and 1 pull when warm (at 3/4 choke with the throttle in start position.) Can I run Seafoam through the carburetor or do I need to rebuild the carburetor and/or rebuild the fuel pump?
