thanks in advance for any help. start with some history, got this boat with a 1993 50 horse evenrude and it had no spark so i started testing the ignition and here is what i found. tested the stator and had 1200 ohms resistance on the brown to brown yellow,specs are 500 to 700. had 409 on the orange to orange black, specs are 45-60. knowing that these specs are out i tested the dva output of the stator and had 275 volts on the b to b/y and 12.7 on the o to o/b these numbers are within specs. tested the timer base, tested fine. resistance check on coils showed same numbers on both coils primary and secondary sides .290 on both primaries and .289 on the secondaries.in my expieriance with coils the secondary numbers should be around .6. here is my question when i checked the voltage on the kill circuit which i have read should be no more that two volts at any time, i get voltage readings over 200 volts, i have replaced the power pack and now have spark but still have the voltage on the black/yellow wire coming from the pack and dont want to damage the new power pack without knowing where this voltage is coming from. are the numbers for the coils ok or is the resistance numbers out and causing the problem or the high resistance numbers on the stator the cause of the problem. thanks again for any help
