Hi I'm looking for anyone who might know the fuel ratio mix for this engine. Just bought it and its running smokey so I'm assuming its over oiled. Anyone?
A bit smokey is normal for that engine if you are using petro based oil at a 50:1 ratio (the correct mix). You can reduce the smoke by using the more expensive synthetic oils.
