Hi all. My problem is that my 28 hp 1987 evinrude is having strange water pumping issues. The Tell Tale cuts out at higher rpm but works fine at idle. I already installed a water pump repair KIT, not just the impeller. I also replaced a faulty head gasket. I Tested both cylinders and they are dead even @ 105 Psi. I also hooked up my compressor to the tell tale and blew it out. There is so little resistance i can breath through it. here is a link to a video I took of the problem. 1987 28hp evinrude waterpump issues - YouTube
