Ulbricht Nicht
- Jun 10, 2013
- 3
I recently purchased a little fishing boat with two Evinrude motors. Both required minor tinkering and tuneup but both have good compression and run like tops. That was the 'easy' part.
How I am rewiring all but the harness. (The previous owner thought that household wiring should work fine. *Shudder*) Anyway, I now have everything in either 14Ga or 12 Ga (For primary power only) marine grade wiring running from everything from the air horn to the depth finder. That is the other 'easy' part. Now I am trying to decipher the junction box itself. [I have a SELOC manual and keep it mostly just in case somebody runs out of toilet paper or facial tissue. Do NOT waste your money on one of these even if the proper manual is out of print and unavailable through the 'vintage' suppliers!]
I also have a parts manual and after spending money on that I found almost an exact duplicate online for free: http://www.marineengine.com/parts/vintage-evinrude-johnson/278649/27864900001.htm] Vintage Evinrude Johnson Outboard Parts & Diagrams - Catalog 278649 Page 21
What none of this shows me is which, if any, of terminals 64 through 67 is intended for accessories. Specifically, I would like the running/navigation lights to pass through the key relay to prevent them from being able to be turned on while the key is not in the 'on' position.
So, getting to the meat in the middle of the sandwich here, Is anyone familiar with the Evinrude 40552A electrical junction box who is also willing to tell me if what I hope to do is possible?
Thank you.
Thank you.
