phoenixgold2100
- Feb 3, 2013
- 154
I was out fishing last weekend when my tach started jumping around then just stopped working.
I put a volt meter on the battery while it was running and had 14v.
The tach worked a few more times for a second at a time then just completely died.
I just confirmed it's wired properly and the sender wire is not broken/burnt anywhere.
I just installed a volt gauge and started the engine 12+ volts on the gauge no tach.
Volt meter the battery while running 12.78v.
So I have to believe it is not charging my battery now also it had 11.9 volts in it before charge.
How do I test the rectifier or do I just change it now that I know it's not charging and no tach, common symptoms of a crapped out rectifier..
Also my engine has a rectifier from a 1995 in it and it doesn't have the plug on the purple and gray wire it just has butt connectors with the plastic cover.
My question is can I use a rectifier from another year and just cut out the plug and add these connectors?
Thanks boys.
Thanks boys.
