Re: 1971 60 hp Evinrude no spark to plugs
Temporarily remove the cable from the electric starter. Now, with the key in the RUN, then the START position, check to make sure that you do indeed have 12v applied to the amplifier. Reattach the cable to the starter.
The point setting on that model is critical. Clean the points with either lacquer thinner or acetone, then set as follows:
(Point Setting Of Battery Capacitance Discharge)
( Ignition Models - 1968 thru 1972)
(Some have points - Some do not)
(Joe Reeves)
The points must be set to .010 but no wider than .010..... BUT in some instances due to a possible slight inaccurately machined crankshaft lobe or a slight offset of one set of points, a setting slightly less than .010 would be required as follows.
Whether the crankshaft has two or three lobes, when setting the points, check the setting of the points on each individual lobe by rotating the crankshaft by hand.
You may find that setting one set of points to .010 on one lobe, then turning the crankshaft to the next lobe, the gap measures .011 or .012 (too wide). This is where you would need to close that gap down to the required .010. A gap too wide can result in a ignition miss when throttle is applied.
Bottom line, pertaining to the point setting at the various lobe locations____ .010, .010, .009, is okay____ .010, .010, .011 is not!
Let us know what you find.
