Olias
- May 28, 2013
- 99
Don't know if other older Evinrudes have this same spring and washer on the crankshaft but mine does and causes me problems. I'm referring the metal washer and spring directly under the cam. My problem is that when ever I have the flywheel off to set/adjust my points the cam springs up out of position so that the arms on the points that detect the high/low spots on the cam don't make contact. So if I want to adjust my point gap I have to physically push down and hold the cam in place with one hand which of course makes the whole process pretty impossible. I think or at least thought that maybe my woodruff key was to worn so as not to be grabbing/holding onto the cam enough to hold it down in place. Have tried several different keys to no avail. Still have the same problem. So my question is, what the heck is that spring for any way? If it weren't there my cam would seat all the way down like I think it should, but, I know good and well that the spring is there for a reason. Any tips? Thanks
-B-
-B-
