stratosguyTN
- Oct 8, 2012
- 14
I have a '95 Johnson Fast Strike that slowly shut down on me while running full throttle. Here's some history: I purchased the boat about a year ago. It ran and started fine upon first crank. Leaving the ramp, it would come out of the hole perfectly with no hesitation. Once I would run to my first fishing hole and fished (about an hour) it would still start fine. Upon take off, it would bog down when you mash on it to come out of the hole. I got around this but pushing in the key (choke). Once, I pushed in the choke for a second or two, it would take right off and run like a champ. Now, unless I keep squeezing the primer bulb, it wont continue to run. Example: Squeeze bulb 4-5-6 times till its firm, start engine (starts fine), then after about 30 seconds, it spits sputters, and then dies. The primer bulb will be completely soft and I have to re-prime it for it to start back. Note: the bulb doesn't collapse and is less than a year old. If I keep squeezing the bulb as its running, it will keep idling just fine. I have troubleshot it enough to know its losing fuel pressure somehow. No fuel leaks are visible. I really don't think its the fuel tank or primer bulb. Need some help here as this is really weighing heavy on my mind.
