SeaChaser175
- Jun 24, 2013
- 3
My outboard started running rough like a bad plug and I noticed oil coming from exhaust while running with muffs. I pulled the plugs and all 3 were wet with black soot. I looked into the plug holes and can see black crude on pistons. I checked spark with OEM spark tester and all three wires jumped 1/2" gap. The motor will still push the boat at 30 mph with me and my two boys so it appears to have power but when I increase throttle it sounds like plug is missing. I checked compression but not sure about the seal. All three cylinders showed equal compression but gauge didn't hole the pressure. Could I have mixed too much oil in fuel? Any suggestions would be appreciated. I'm new to the forum.
