78Ranger91
- Jun 23, 2013
- 6
I have a 1991 Evinrude/Johnson 90 HP that does not charge while running. Luckily, I have two batteries in the boat and was able to use the trolling motor to get me back. Partially charged the battery. Voltage now is 12.3 engine not running and the voltage drops slowly while the engine is running. here is a link a diagram. I don't have a tach, so checking tach is a no go. This diagram say's it's for a 1986, but it is identical to my 1991. I de-coded my model # and it is diffidently a 91. http://www.maxrules.com/graphics/omc/wiring/1986_90_115.jpg
I assume that if I unhook the battery and the engine stays running that this must mean the stator is good? I didn't see this on a flow chart, but if the stator is producing enough energy to provide spark to the coils/plugs then it must be working correct??
Next thing I did was put my multimeter on DC volts and checked from the yellow/grey wire to ground and found 6.5 volts DC at roughly 1500 rpm. I then checked the yellow wire to ground and found around 6 volts on the yellow wire. I then checked for voltage on the red wire leaving the regulator and found zero volts.
(I confirmed zero volts on the red wire leaving the regulator by checking pin #4 on the terminal block to ground and found zero volts. I later checked resistance from terminal #4 to the red wire on the voltage regulator and found 1 ohm of resistance.)
So, I ASSUME this means that the stator is putting out voltage to the regulator, but the regulator is not turning the voltage to dc and sending it back to the battery? Next thing I did was check A/C voltage across the yellow and yellow/grey wire and found around 24v A/C at idle and around 70v A/C at around 2500 RPMS. I again assume this means the stator is working correctly? Is there a "correct" way to test stator output and is there a spec for that test?
Please help me confirm this before I purchase an $79 rectifier/regulator.
Also, my model # boat moter model # is te90tleie. When I google my model # and the word rectifier I come up with this part # 0584204. Found per this website http://www.**********/parts/detail/brp/B-0584204.html .
Is this a common failure part? Is there a place to get this for less than the $79-80 that boats dot net sells it for?
For some reason this website takes the part of the link that says boats dot net and it out. not sure why, but the astericks in the link need to be changed to boats dot net.
If this is a competitor let me know and I'll remove the link?
