Back Story: I just bought a '98 Seaswirl Striper 2300 that was sitting at the local marina for 1.5 years. I changed all fluids, drained old gas, installed new water/fuel sep, new spark plugs, new filter on the motor. Carbs cleaned. The prop is a 17 pitch. Starts great, idles great.
Problem: Motor wont go above 4,000 rpms, runs good though, 19 mph. It starts first bump of key, idles all day, no misses sputtering nothing. clean as a whistle to 4k and then it doesnt do anything else.
Fixed so far: New plugs, carbs cleaned, water/fuel sep, new filter on the motor, new stator as it had a burned up coil, all new fluids. I am running double oil right now (i didn't know if the VRO worked) so it has 50:1 in the tank as well as pumping oil.
Next on the list: Compression check and making sure the butterflys are full open under full throttle
Thoughts?
Thoughts?
