Re: 1985 Evinrude E70TLCOS Choke Problem
Schematic, Thank you for bearing with me on this,
No I do not have fuel pouring from the carb when i pump the bulb, the bulb gets rock hard
yes i used all fresh gaskets needle and seat when doing the carb
yes the float was adjusted to the carb body
I am at a loss on this one, Today is normally one of my boating days and instead i am going to pull the carb again and just take a real hard look at it!
I also do use a 50-1 fuel mix and seafoam in every tank
