Re: 1997 Johnson 35 HP trim/tilt
be careful tapping the motor. you can crack the magnets and cause the motor to break within a few months. when you tap it, if you tap it, then tap lightly on the top (not the sides).
better yet. hot wire the motor directly to a battery and see if trim works. If it does then you have a relay, switch, or wiring problem.
