Hello everyone...
I have a Johnson Seahorse V4 85hp outboard motor #85EL76 that is incredibly difficult to cold start. Once I have it started it runs great. The only way I am able to cold start it is by jumping the already fully charged battery with a jumper pack. I have replaced the battery and the problem still persists. I have checked some of the obvious items such as spark, fuel and compression. I have rebuilt the carbs and the linkage appears to be correct. Again, it runs excellent once it starts and will stay running, works under load and will continue to run great all day as long its not off for more than an hour or two. It seems as though it doesn't have enough amps to start under its own power however I am using a deep cycle marine battery rated at 845 cranking amps.
Any thoughts or help would be greatly appreciated. It would be great to leave the jumper pack at home when we hit the lake!
