cclements716
- Feb 17, 2011
- 97
Boat has ran great until a few days ago. Tach stopped working. The engine is charging the battery but I have no signal at the tach. When I turn the key on the gauge zeros and has a good ground and positive feed. I have checked on the block and connected the yellow/gray with the gray and still no reading. I have completed the rectifier test with an ohm meter and only shows movement in one direction. Brand new batteries and clean connections. The vro has been disabled (unplugged) and the engine has ram fine without it. Never had any problems with the tachometer until now. Any suggestions?
