bplayer405
- May 3, 2013
- 29
I went through a lot with this motor over the last month so I thought I'd post an update. I converted the two line fuel system to a single line. I used a Minuki style snowmobile fuel pump that runs off the same pressure port on the intake that used to pressurize the old tank. I removed the check valves from the reed plate and plugged one check valve port to give the fuel pump its pulse signal. I realize there was another way to do it that is easier; porting one of the side covers for the pulse and plugging off the pressure port. Anyway, after having a slipping prop hub and a fuel line that the inside liner was collapsing {now a new prop and all hoses replaced also replaced the upper crank seal}, the motor runs perfect! This little motor pushes my 1648 ex wide and deep fully decked jon around 20mph! All that said, doing the fuel pump conversion was definately worth the effort!
