Re: 1971 60 hp Evinrude Link & Sync
It wasn't running when I bought it, so I bought a new coil (it doesn't have the power pack on it, converted to a coil).
It fired up and ran, idled rear rough though.
So I bought a carb kit for all three carbs.
Rebuilt them, several times. Had my neighbor check and make sure I had everything together and adjusted as such.
It fired, ran fine on muffs, took it to the lake, it idled bad.. Then as I was getting onto a plane, it died and would not start again.
Neighbor came by, held the choke slightly open and it would start and run, but that was the only way.
Had a spark test done on it, the boat guy said it was a strong blue park on all three.
Compression was 90, 110, 120
Replaced ALL the fuel lines and replaced the fuel pump.
Was told my problem may be the fuel pump diaphragm so I just got a new one.
I did the carbs as you suggested in your write up.
I was in the process of doing a decarb (1 gallon of fuel mix
il to 3/4 can of sea foam)
It ran for 10 minutes, died and will not restart for the life of me.
Neighbor had adjusted all the idle/throttle parts previously.
I just got back in from taking the carbs back off for the 100000th time and making sure it was all clean and clear and all the floats were set, needles set, etc.
No leaks in any of my fuel lines at all.
I'm so confused and no one locally wants to touch this motor.
Decarbing and fogging low cylinder was my goal, just to get it up and running "enough".
